df = dt << Data Filter(
Where( :sex == "F" ),
txt = df << Get Script;
Show( txt );
filter = dist << Local Data Filter( Add Filter( Columns( :Region ) ) );
rs = filter << Make Filter Change Handler( f );
Sets the filter conditions for each column. The WHERE clause is used for all the columns listed. To use different WHERE clauses for different columns, send the Match message separately for each column.
