发布日期: 08/07/2020
Material Properties
To set the material properties of a surface, use the Material command.
Material( face, argument, value,...value )
face can be Front, Back, or Front_and_back. (Note that the material properties can be set separately for the front and back faces of a polygon.)
Material Arguments and Default Values shows the arguments and default values for Material arguments.
Argument
Default Value
Meaning
AMBIENT
(0.2, 0.2, 0.2, 1.0)
Ambient color of material
DIFFUSE
(0.8, 0.8, 0.8, 1.0)
Diffuse color of material
AMBIENT_AND_DIFFUSE
Both AMBIENT and DIFFUSE
SPECULAR
(0.0, 0.0, 0.0, 1.0)
Specular color of material
SHININESS
0
Specular exponent that can range from 0 to 128.
EMISSION
(0, 0, 0, 1)
Emissive color of material
