JSL Syntax Reference > JSL Messages > Python Integration Messages
发布日期: 08/07/2020
The Python interfaces are also scriptable using a Python connection object. A scriptable Python connection object can be obtained using the Python Connect() function. See Python Connect(<Echo(Boolean),> <Path(path),> <Use Python Version("string"),> <Python System Path(list)>).
pythconn<<Control(<Interactive(Boolean)>|<Echo(Boolean)>)
Description
Controls the execution of Python.
Optional Named Arguments
Enables interactive mode in the Python matplotlib package. Determines whether the graphics window is released or closed when graphics rendering is complete.
Echo(Boolean)
Global argument. Prints the Python source lines to the JMP log. The default value is true.
pythconn<<Disconnect
Disconnects the Python integration interface connection.
pythconn<<Execute({list of inputs}, {list of outputs}, Python code, <named arguments>)
Description
Submits Python code to the active global Python integration interface connection given a list of inputs. On completion, returns a list of outputs.
Returns
Returns 0 if successful and 1 otherwise. The results are returned using the list of outputs. Given each element of the JMP output list, the corresponding Python variable value is returned.
Positional Arguments
{list of inputs}
A list of JMP variable names to be sent to Python as inputs.
{list of outputs}
A list of JMP variable names to be retrieved from Python as outputs.
Python code
The quoted Python code to submit.
See pythconn<<Submit(Python code, <Expand(Boolean)>, <Echo(Boolean)>).
pythconn<<Get(name)
Description
Gets a named variable from Python.
Returns
Returns the value of the named variable.
Argument
name
The name of the JMP variable to be received from Python. The argument can represent any of the following Python data types: numeric, string, matrix, list, or data frame.
pythconn<<Get Graphics(format)
Description
Gets the last graphics object written to the Python graph display window in the specified graphics format. The graphics object can be returned in several different graphic formats.
Returns
Returns a JMP picture object.
Argument
format
The format that the Python graph display window contents are to be converted to. Valid formats are PNG, BMP, JPEG, JPG, TIFF, and TIF.
pythconn<<Get Version
Description
Gets the current version of the Python installation.
Returns
Returns a list of length 5 that contains the five components of the version number: major, minor, micro, releaselevel, and serial. The releaselevel value is a string.
pythconn<<Is Connected
Description
Determines if the connection is active.
Returns
Returns 1 if connected and 0 otherwise.
pythconn<<JMP Name to Python Name(name)
Description
Maps a JMP variable name to its corresponding Python variable name using Python variable name naming rules.
Argument
name
The name of the JMP variable to be sent to Python. Some variable names allowed by JMP are not allowed by Python. When you send using these variables from JMP to Python (the Send message), their names get changed. Use JMP Name to Python Name to determine what the variable name was changed to.
pythconn<<Send(name)
Description
Sends a named variable from JMP to Python.
Returns
Returns 0 if successful and non-zero otherwise.
Argument
name
Description
Submits Python code to the active global Python integration interface connection.
Returns
Required Arguments
Python code
Optional Arguments
Expand(Boolean)
Performs an Eval Insert() on the Python code before submission.
Echo(Boolean)
pythconn<<Submit File(path)
Description
Submits statements to Python using the quoted path name.
Argument
path
The quoted path to the file that contains the Python source lines to be executed.
