Select Help > Sample Data Library and open Design Experiment/Reactor 8 Runs.jmp.
Select DOE > Augment Design.
Select Percent Reacted and click Y, Response.
Select Feed Rate, Catalyst, Stir Rate, Temperature, and Concentration and click X, Factor.
Select Group new runs into separate block to add a blocking variable to the design.
7.
Click Add Axial, enter 1 for axial value, 2 for number of center points, and then click OK.
8.
Click Make Table.
9.
From the Augmented Design table, select Rows > Color or Mark by Column.
10.
Select Block, from Markers select Standard, and then click OK.
11.
Select Graph > Graph Builder.
12.
Drag Feed Rate to Y and drag Catalyst to X and then click the smoother icon to remove.
Graphical View of the Augmented Design for Two Factors
Help created on 9/19/2017
