Select Help > Sample Data Library and open Design Experiment/Reactor 8 Runs.jmp.
Select DOE > Augment Design.
Select Percent Reacted and click Y, Response.
Select Feed Rate, Catalyst, Stir Rate, Temperature, and Concentration and click X, Factor.
Select Group new runs into separate block to add a blocking variable to the design.
7.
Click Fold Over and then click OK.
Foldover Design on All Factors
8.
Click Make Table.
Help created on 9/19/2017
