To add items using the Project menu, right-click on the project name in the Projects window and select the desired command.
Opens the JMP database query Window, where you can create or open a query to a database. This query is then added to the project. For detailed information about creating queries, see Import Data from a Database in Import Your Data.
Lets you add a SAS Stored Process. If you are not connected to a SAS Metadata Server, you are either connected to the server using your saved profile, or the SAS Server Connection window is opened for you. Once you are connected, you can select the SAS Stored Process to add to the project. See Run Stored Processes in Import Your Data.
