Note: Links to files have absolute paths. If you move the journal to another location on your computer, the links continue to work. When adding links to files in the JMP sample data folder, use the pathname $SAMPLE_DATA/xx. xx is the absolute path from the sample data directory. (Right-click the link, select Edit > Set Script, and then edit the path.)
To add an outline level, right-click in the journal, and then select Append Item > Add Outline Item. You can also add nested outline levels to outline levels that you have created. (When you click the red triangle menu of a graph that you have journaled, the Add Outline Item option is unavailable.) Click the outline level’s red triangle menu and select Add Outline Item.
To edit a link, right-click the link, select Edit > Set Script, edit the path, and then click OK.
Creates outline levels and links to open files in JMP (except for the log). For example, a link to the open Big Class.jmp data table and chart is displayed below a collapsible heading named Big Class. Files such as journals, scripts, and tutorials are grouped below a collapsible heading called Other Files.
Help created on 9/19/2017
