Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Using JMP
Save and Share Data
JMP Journals
• Append Reports to a Journal
To append other reports to a report that you already journaled, select
Edit > Journal
again. If an area of an analysis window is selected,
Edit > Journal
saves only the selected area instead of the entire window.
Notes:
The journal window has the same functions as the report window: you can click icons, click and drag, and right-click to access menus.
When a report is journaled, the journaled copy is no longer connected to the data table.
Help created on 9/19/2017
