Alias Matrix Summary for Two Designs
Alias Matrix Summary for Two Designs shows the Alias Matrix Summary report for the Plackett-Burman and Definitive Screening designs constructed in Designs of Same Run Size, with only main effects in the Model outline. All two-factor interactions are in the Alias Terms list. The table shows that, for the Definitive Screening Design, main effects are uncorrelated with two-factor interactions.
Select Help > Sample Data, click Open the Sample Scripts Directory, and select Compare Same Run Size.jsl.
From the Plackett-Burman table, select DOE > Design Diagnostics > Evaluate Design.
Select X1 through X6 and click X, Factor.
For example, to obtain the Alias Matrix Summary entry in Alias Matrix Summary for Two Designs corresponding to X1, square the terms in the row for X1 in the Alias Matrix, average these, and take the square root. You obtain 0.2722.
Help created on 9/19/2017
