Select Help > Sample Data, click Open the Sample Scripts Directory, and select Compare Same Run Size.jsl.
In the Plackett-Burman data table, select DOE > Design Diagnostics > Compare Designs.
Select Definitive Screening Design from the Compare ‘Plackett-Burman’ with list.
Select X1 through X6 in the Plackett-Burman panel and in the Definitive Screening Panel.
Launch Window with Matched Columns
7.
Power Analysis for PB and DSD Comparison
In terms of power, prediction variance, and estimation efficiency, the PB design outperforms the DSD. Power Analysis for PB and DSD Comparison shows the Power Analysis report with the default settings for the significance level, Anticipated RMSE, and coefficients. For tests for the main effects, the PB design has higher power than does the DSD.
Fraction of Design Space Plot for PB and DSD Comparison
Color Maps for PB and DSD Comparison
The Color Map on Correlations plots in Color Maps for PB and DSD Comparison show that the PB design aliases main effects with two-way interactions. In contrast, the DSD does not alias main effects with two-way interactions.
Power Analysis for PB and DSD Comparison with Interactions
Prediction Variance for PB and DSD Comparison with Interactions
Help created on 9/19/2017
