Launch the Compare Designs platform by selecting DOE > Design Diagnostics > Compare Designs. All open data tables appear in the list at the left. The active data table and its columns appear in a Source Columns panel. The design in the initial Source Columns panel is the reference design, namely, the design to which other designs are compared. When you add designs to compare to the reference design, their columns appear in panels under the reference design panel.
Compare Designs Launch Window shows the launch window for the three designs in Designs of Different Run Sizes.
Selection of Columns for Matching
Help created on 9/19/2017
