Select Help > Sample Data, click Open the Sample Scripts Directory, and select Compare Three Run Sizes.jsl.
Right-click in the script window and select Run Script.
You want to compare these three designs. Notice that the 16-Run Design table is active.
Click OK.
7.
8.
In the Model outline, select Interactions > 2nd.
9.
Click OK.
The other two effects, X1*X3 and X2*X3, are added to the Compare Design report. You can examine the report to compare the designs if the two interactions are active.
