If the contour plot includes a Color role, the Transform option is enabled. See Example of Triangulation, Transform, and Alpha Shapes for details.
Fills the areas between the contours with a solid color. It is the same option that is available in the Launch window. If you leave it deselected in the Launch window, you can see the line contours before filling the areas. See Fill Areas.
Shows or hides the label (z-value) of the contour lines.
This menu has options to save information about contours, triangulation, and grid coordinates to data tables. See Contour Plot Save Options.
See Local Data Filter, Redo Menus, and Save Script Menusin the Using JMP book for more information about the following options:
