Select Help > Sample Data Library and open SATByYear.jmp.
From any JMP window, select View > Create Web Report.
Click Next.
Customizing the Web Report
6.
Enter SAT By Year Reports in the Web Report Title box.
7.
Click Build Report.
Web Report
Enables you to specify a CSS file to format the web page. The CSS file is copied into a subdirectory called _css. The link to the CSS file is relative so that you can send the report and support files to another user and maintain the CSS formatting.
Help created on 9/19/2017
