Select DOE > Special Purpose > Space Filling Design.
Alter the factor level values, if necessary. Space-Filling Dialog for Four Factors shows adding two factors to the two existing factors and changing their values to 1 and 8 instead of the default –1 and 1.
Click Continue.
In the design specification dialog, specify a sample size (Number of Runs). This example uses a sample size of eight.
6.
Click Latin Hypercube (see Space-Filling Design Dialog). Factor settings and design diagnostics results appear similar to those in Latin Hypercube Design for Four Factors and Eight Runs with Eight Levels, which shows the Latin Hypercube design with four factors and eight runs.
Help created on 9/19/2017
