Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Evaluate Designs
Evaluate Design Window
• Design Evaluation
Design Evaluation
Design Evaluation within the Evaluate Design platform is based on your design and the specifications that you make in the Model and Alias Terms outlines. Several DOE Design platforms provide a Design Evaluation outline: Custom, Definitive Screening, Screening, Response Surface, and Mixture with Optimal design type. Design Evaluation within these platforms is based on the design that you construct.
The Design Evaluation outline contains eight headings:
Power Analysis
Prediction Variance Profile
Fraction of Design Space Plot
Prediction Variance Surface
Estimation Efficiency
Alias Matrix
Color Map on Correlations
Design Diagnostics
Help created on 9/19/2017
