Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Modeling Utilities
Explore Outliers Utility
• Explore Outliers Utility Options
See
Redo Menus
and
Save Script Menus
in the
Using JMP
book for more information about the following options:
Redo
Save Script
Save By-Group Script
Help created on 9/19/2017
