Creates a prediction formula and saves it as a formula column script in the Formula Depot platform. If a Formula Depot report is not open, this option creates a Formula Depot report. See the Formula Depot topic.
Creates a variance formula and saves it as a formula column script in the Formula Depot platform. If a Formula Depot report is not open, this option creates a Formula Depot report. See the Formula Depot topic.
Saves the jackknife predicted values to the active data table. These are the x-axis values for the Actual by Predicted Plot.
See Local Data Filter, Redo Menus, and Save Script Menusin the Using JMP book for more information about the following options:
