When you click Run in the Fit Model launch window, the Generalized Regression report window appears showing:
A Model Launch control panel for fitting models. See Model Launch Control Panel. As you fit models, outlines are added with titles that describe the types of models that you have fit. See Model Fit Reports and Model Fit Options.
See Local Data Filter, Redo Menus, and Save Script Menusin the Using JMP book for more information about the following options:
