Select File > Preferences (Windows) or JMP > Preferences (Macintosh).
SAS Submit Options in Preferences
Select the Automatically generate ODS results option.
From the ODS Result Format list, select the format in which to generate the ODS results: HTML, PDF, RTF, or a JMP report.
Help created on 9/19/2017
