Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Capability Analysis
Capability Platform Options
• Normalized Box Plots
When drawing Normalized Box Plots, JMP first standardizes each column by subtracting off the mean and dividing by the standard deviation. Next, quantiles are formed for each standardized column. The box plots are formed for each column from these standardized quantiles.
Normalized Box Plot
Normalized Box Plot
shows the Normalized Box Plot for the
Semiconductor Capability.jmp
sample data table.
The green vertical lines represent the spec limits normalized by the mean and standard deviation. The gray dotted vertical lines are drawn at ±0.5, since the data is standardized to a standard deviation of 1.
Help created on 9/19/2017
