Shows a goal plot for the data. The Goal Plot shows the spec-normalized mean shift on the x-axis, and the spec-normalized standard deviation on the y-axis for each variable. See Goal Plot for more information.
Shows a normalized box plot for the data. Each column is standardized by subtracting off the mean and dividing by the standard deviation, and quantiles are formed for each standardized column. The box plots are formed for each column from these standardized quantiles. See Normalized Box Plots for more information.
Shows a capability box plot for each variable in the analysis. The values for each column are centered by their target value and scaled by the difference between the specification limits. See Capability Box Plots for more information.
Makes a summary table for the data that includes the variable’s name, its spec-normalized mean shift, and its spec-normalized standard deviation. See Make Summary Table for more information.
Shows a capability indices report for the data showing each variable’s LSL, Target, USL, Mean, Standard Deviation, Cp, CPK, and PPM. See Capability Indices Report for more information.
Shows individual detail reports for each variable in the analysis. See Individual Detail Reports for more information.
Enables you to reorder box plots, capability indices reports, and individual details reports. You can reorder by Initial Order, Reverse Initial Order, CPK Ascending, or CPK Descending.
See Local Data Filter, Redo Menus, and Save Script Menusin the Using JMP book for more information about the following options:
