Note: The header and footer defined in your printer setup appears in the PDF file. However, you can set the left, center, and right header and footer in a JSL script. For more information, search for the Set Print Footers message in the JMP Scripting Index. (Select Help > Scripting Index in JMP.)
Select File > Save As.
Click OK.
Select File > Export.
Click Next.
Enter a name for the file in the Save As box.
Click Export.
