Enter the size of the sample that you want in the box under Sample Size (>1) or Sampling Rate (<1), as shown in The Test Build Panel. The size of the sample can be either the proportion of the active table that you enter or the number of rows from the active table.
Click Resample.
To see the sampled data in a JMP data table, click the Test Data View button. When you dismiss the test build panel, Tabulate uses the full data table to regenerate the tables as designed.
Help created on 9/19/2017
