Displays the summarized data in bar charts that mirrors the table of summary statistics. The simple bar chart enables visual comparison of the relative magnitude of the summary statistics. By default, all columns of bars share the same scale. You can have each column of bars use the scale determined separately from the data in each displayed column, by clearing the Uniform plot scale check box. You can specify a uniform custom scale using the Change Plot Scale button. The charts are either 0-based or centered on 0. If the data are all nonnegative, or all non-positive, the charts baseline is at 0. Otherwise, the charts are centered on 0.
Displays the control area that lets you create a test build using a random sample from the original table. This is particularly useful when you have large amounts of data. See Show Test Build Panel.
See Local Data Filter, Redo Menus, and Save Script Menusin the Using JMP book for more information about the following options:
For a description of the options in the Select Columns red triangle menu, see Column Filter Menu in the Using JMP book.
