Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 12 Online Documentation
Accelerated Life Test Designs
Accelerated Life Test Plan Window
• Specify Acceleration Factors
Specify details about the acceleration factor or factors.
ALT Specification Window
Factor Name
Enter a name for each acceleration factor.
Number of Levels
For each acceleration factor, enter the number of proposed levels that you want to include in the experiment.
Factor Transformation
Select a transformation for each acceleration factor. This transformation describes the life-stress relationship, which is the manner in which the life distribution changes across stress levels. The transformations are Arrhenius Celsius, Reciprocal, Log, Square Root, and Linear.
Low Usage Condition
For each acceleration factor, enter a lower bound for its value in typical usage conditions.
Note:
The Low Usage Condition and High Usage Condition values can be identical.
For each acceleration factor, enter an upper bound for its value in typical usage conditions.
Help created on 9/19/2017
