Select Cols > New Columns. Use this option to add one or more columns and change their attributes.
Notes:
By default, the new column names are Column 1, Column 2, and so on.
a.
Click Apply to add the new column.
b.
Click Next, change the column properties, and then click Apply.
c.
Click Next to add another column.
9.
Click OK to save your changes.
Figure 3.2 The New Column Window
Figure 3.3 Adding Multiple Columns
8.
Help created on 10/11/2018
