JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Using JMP •
Enter and Edit Data
Enter Data
• Fill Columns with Sequential Data
To fill columns with a repeating sequence of data or with a continuation of values, follow these steps:
Create a sequence of data in a column. See
Figure 3.4
Figure 3.4
Example of a Sequence of Data
Highlight the cells containing the sequenced data. The cells can be in different columns.
Right-click the selected cells and select an option under
Fill
Fill Options
Repeat sequence to end of table
cells below the selection are filled with repeats of the selected cells.
Continue sequence to end of table
cells below the selection are filled with a continuation of the pattern found in the selected cells. For example, if the selected cells contain the numbers 1 and 2, then the remaining cells are filled with 3, 4, 5, 6, and so on. If the selected cells contain the numbers 2 and 4, then the remaining cells are filled with 6, 8, 10, 12, and so on.
Repeat sequence to
JMP repeats the pattern found in the selected cells to the row number that you specify.
JMP continues the pattern found in the selected cells to the row number that you specify.
Help created on 10/11/2018
