Provides reports of the Benzecri and Greenacre adjusted inertia. See Benzécri (1979) and Greenacre (1984). This option is not available when there are one or more X variables. See Show Adjusted Inertia.
(Available only when all of the Y variables have the same set of only two levels and the X variable has a unique value for each row.) Provides Cochran’s Q statistic, which tests that the marginal probability of a specific response is unchanged across the Y variables. Cochran’s Q statistic is a generalization of McNemar’s statistic for more than two response variables. See Agresti (2013).
Help created on 10/11/2018
