Select View > Customize > Menus and Toolbars.
Select Insert Before or Insert After.
Figure 11.2 Specify Type Window
To create a menu within a menu, select Submenu. (Not available for buttons.)
6.
Click the Localize button for the item that you want to customize.
Select Run JSL in this file, and then browse to find the external file.
Type the relative path to the JSL script, and select the add-in from the Use add-in home folder list. For example, the following command runs the mds_application.jsl script from the selected add-in:
$ADDIN_HOME(com.jmp.mdswithr)/mds_application.jsl
In addition, you can select Use the “Here” namespace for unqualified JSL variable names if you include namespaces in the internal or external JSL script. See Global and Local Variables in the Scripting Guide book for details about namespaces.
To run an internal JSL script, delete the placeholder text print(“Not implemented.”); in the Run this JSL area and enter the JSL.
(Optional) If your internal or external JSL script includes namespaces, select Use the “Here” namespace for unqualified JSL variable names.
Click Save to save your changes.
Select this option to show an image that you created. Click Browse, select the graphic, and then click OK.
Select this option to display an icon from an add-in to the left of the menu item. After you select the checkbox, select the add-in, click Browse, and then select the icon. The path to the image is displayed in the Use image from file field. The image can be an ICO, PNG, JPG, or BMP graphic.
To assign a new shortcut, click in the New shortcut area and press the shortcut keys. If the keystrokes then appear in the Currently assign to box, press another combination of shortcut keys. (You do not have to delete the keystrokes before pressing the shortcut keys.)
To change a shortcut that you previously specified, click Remove, click in the New shortcut area and press the shortcut keys.
Click Assign.
The shortcut appears in the Current shortcuts list.
Help created on 10/11/2018
