Select View > Customize > Menus and Toolbars.
To paste the item before the selected menu, select Paste before.
To paste the menu after the selected menu, select Paste after.
To paste the menu inside the selected menu, select Paste into. (Available only when you select a menu as the new location.)
7.
Click Save to save your changes.
See Create Main Menus and Create Menu Items and Toolbar Buttons for details about modifying the items.
To paste a toolbar, right-click Toolbar and select Paste. The toolbar appears at the end of the list of toolbars.
To paste a button, right-click the button before or after which you want the new button, and select Paste. If you selected the first button on the toolbar, select the location of the button. Otherwise, the button is pasted below the selected button.
6.
See Create Toolbars and Create Menu Items and Toolbar Buttons for details about modifying the items.
Help created on 10/11/2018
