Figure 2.22 Element Type Icons
Figure 2.23 Example of the Properties Areas for Points and Smoother
Figure 2.24 Graph Showing Points, Smoother, Ellipse, and Contour Elements
As a general rule, when you hide rows but do not exclude them, elements in the plot that are in one-to-one correspondence with the hidden rows are then hidden in the plot. When elements in the plot are not in one-to-one correspondence with rows that are hidden but not excluded, the effect on the plot depends on the element type. For details, see the specific element’s section.
Select Help > Sample Data Library and open Big Class.jmp.
Select Graph > Graph Builder.
Select age and drag it to the X zone.
Go back to Big Class.jmp, right-click on row 8, and select Hide/Unhide.
In Big Class.jmp, select Rows > Clear Row States.
7.
In Big Class.jmp, right-click on row 8, and select Hide/Unhide.
Help created on 10/11/2018
