JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Essential Graphing • Graph Builder
Graph Builder
Create and Explore Graphs
Use Graph Builder to explore multidimensional relationships easily and flexibility. You can quickly create and modify plots using Graph Builder’s interactive interface. Select the variables that you want to graph and drag and drop them into zones.
Use Graph Builder to do the following:
Graph data in a multitude of ways, including line charts, bar charts, histograms, maps, contour plots, and many more.
Experiment by changing the graph type with the click of a button.
Compare groups with overlays or trellis layouts.
Examine and illustrate relationships between several variables of different modeling types.
Use color to highlight aspects of your data.
This chapter shows you how to use Graph Builder to work with plots. For detailed examples using Graph Builder, see
Graph Builder Examples
Figure 2.1
Example Using Graph Builder
Contents
How to Use Graph Builder
About the Graph Builder Window
Example of Features in Graph Builder
Move or Remove Variables in Zones
Work with Axes
Merge Variables on a Common Axis
Create Separate Axes in the X and Y Zones
Create a Second Y Axis
Create Nested Axes for Character Variables
Order the Levels of a Categorical Variable
Element Types and Options
Points
Smoother
Line of Fit
Ellipse
Contour
Line
Bar
Area
Box Plot
Histogram
Heatmap
Pie
Treemap
Mosaic
Caption Box
Formula
Map Shapes
Graph Zones
Categorical and Continuous Variables in Group X or Y Zones
Move Group X and Group Y Labels
Red Triangle Options
Graph Builder Buttons
Right-Click Menus
Graph Options
Grouping Zones Options
Options for Columns in the Variables Panel
Options for Axes, Variable Labels, or Graph Titles
Options for the Dividing Line between Multiple Graphs
Legend Options
Help created on 10/11/2018
