Figure 5.9 shows the one-table launch window populated using Potato Chip Combined.jmp.
Figure 5.9 Launch Window for One Table, Stacked Data Format
A column which, when used with the Choice Set ID, uniquely designates each choice set. For example, if a choice set has Choice Set ID = 1 for Survey = A, and another choice set has Choice Set ID = 1 for Survey = B, then Survey should be used as a Grouping column.
Hierarchical Bayes
Number of Bayesian Iterations
Help created on 10/11/2018
