Select File > SAS > SAS Query Builder.
Connect to all available libraries is selected by default based on the SAS Integration preferences. This option connects metadata-defined SAS libraries automatically across all JMP sessions. When the Workspace Server contains a large number of metadata-defined SAS libraries, consider deselecting this option to speed up your connection to the server.
Notes:
Extended attributes are not imported by default. To import them, modify the JMP SAS Integration preferences. Select File > Preferences (Windows) or JMP > Preferences (Macintosh). Select SAS Integration and then select On import, apply table and column properties from extended attributes.
Help created on 10/11/2018
