JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Quality and Process Methods •
Measurement Systems Analysis
Measurement Systems Analysis Platform Options
• Range Chart or Standard Deviation Chart
The red triangle menu next to Range Chart or Standard Deviation Chart contains the following options:
Show Average Dispersion
Draws the average range or standard deviation on the chart.
Show Connected Points
Draws lines connecting all of the ranges or standard deviations.
Show Control Limits
Draws lines representing the Upper Control Limit (UCL) and the Lower Control Limit (LCL) and defines those values.
Show Control Limits Shading
Adds shading between the UCL and LCL.
Show Separators
Draws vertical lines to delineate between the
X
variables.
Note:
You can replace variables in the Range or Standard Deviation Charts in one of two ways: swap existing variables by dragging and dropping a variable from one axis to the other axis; or, click on a variable in the Columns panel of the associated data table and drag it onto an axis.
Help created on 10/11/2018
