A plot of the average measurement values for each combination of the part and X variables. The Average Chart helps you detect product variation despite measurement variation. In an Average Chart, out of control data is desirable because it detects part-to-part variation. See Average Chart.
A plot of the variability statistic for each combination of the part and X variables. Appears only if you selected Range as the Chart Dispersion Type in the launch window. The Range Chart helps you check for consistency within subgroups. In a Range Chart, data within limits is desirable, indicating homogeneity in your error. See Range Chart or Standard Deviation Chart.
A plot of the standard deviation statistic for each combination of the part and X variables. Appears only if you selected Standard Deviation as the Chart Dispersion Type in the launch window. The Standard Deviation Chart helps you check for consistency within subgroups. In a Standard Deviation Chart, data within limits is desirable, indicating homogeneity in your error. See Range Chart or Standard Deviation Chart.
An Analysis of Means chart for testing if the X variables have different averages. See Bias Comparison.
See Local Data Filter, Redo Menus, and Save Script Menus in the Using JMP book for more information about the following options:
Help created on 10/11/2018
