Rearrange Custom Menus, Menu Items, and Buttons
On Windows, you can rearrange the order of menus, menu items, and buttons that you create. For example, under the File > New menu, you could move your custom menu before the Data Table command.
In the item’s General properties, the Source determines whether you can move the item. You can move items if the Source is Custom Item. Built-in items cannot be moved. Items that are defined in other customization sets can be moved only in that customization set. See Change Customization Sets for details.
Select View > Customize > Menus and Toolbars.
If the Source is All Users or JMP Add-In, select the specified customization set and verify that the Source is Custom Item.
A list appears with the possible locations of the cut item. This occurs when you select a menu (such as File or New) or the first item in a menu (such as Data Table in the File > New menu).
To paste the cut item before the selected item, select Paste before.
To paste the cut item after the selected item, select Paste after.
To paste the cut item inside the selected menu, select Paste into. (Available only when you select a menu as the new location.)
6.
Click Save to save your changes.
To paste the cut button before the selected button, select Paste before.
To paste the cut button after the selected button, select Paste after.
6.
Help created on 10/11/2018
