Select File > Preferences (Windows) or JMP > Preferences (Macintosh).
Select the Import generated SAS data sets into JMP option.
Select File > SAS > Export Data to SAS.
Figure 2.28 Export Data to SAS
10.
Click Export.
Define an autoexec.sas file that runs a snippet of SAS code every time SAS is invoked. This creates the same librefs every time you connect to SAS. For details about autoexec.sas files, see the SAS documentation.
Help created on 10/11/2018
