Select File > Preferences (Windows) or JMP > Preferences (Macintosh).
Figure 2.27 SAS Submit Options in Preferences
Select the Automatically generate ODS results option.
From the ODS Result Format list, select the format in which to generate the ODS results: HTML, PDF, RTF, or a JMP report.
Help created on 10/11/2018
