JMP 14.1 Online Documentation (English)
Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Essential Graphing •
Graph Builder
• Right-Click Menus
Right-Click Menus
Graph Options
Grouping Zones Options
Options for Columns in the Variables Panel
Options for Axes, Variable Labels, or Graph Titles
Options for the Dividing Line between Multiple Graphs
Legend Options
For multiple graphs (created with grouping zones or the Wrap zone), note the following:
Generally, any options that you apply to one graph element apply to all graphs, across all grouping and wrap variables.
To apply an option to only one graph, right-click in that graph area and select the option from the Graph menu.
To apply an option to all of your multiple graphs simultaneously, first hold down the Ctrl key and right-click and then select the option from the Graph menu.
Help created on 10/11/2018
