Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Using JMP
JMP Reports
Change the Appearance of Graphs
• Resize Graphs
JMP.com/help
Resize Graphs
There are two main ways to resize graphs: using the click and drag method or resizing it according to pixel size.
Note:
You can also change the default size of a graph using the Graph Height option in File > Preferences > Graphs.
Use Click and Drag
To resize a plot or graph using the click and drag method:
Place the cursor on the right edge, bottom edge, or lower right corner of the plot frame. The cursor changes to a small double-arrow pointer.
Click and drag to change the size of the plot. When you resize, the height and width of all plots in that frame adjust independently of other frames in the same report window.
Table 9.2
describes how to adjust the plot.
Table 9.2
Resizing Actions
Action
Instructions
Adjust the plot frame but preserve the proportions (aspect ratio)
Hold down the Shift key and click and drag the corner of the frame.
Adjust a plot in 8-pixel increments
Hold down the Alt key and click and drag the corner of the frame.
Adjust all plots of the same type simultaneously
Hold down the Ctrl key and click and drag the corner of one of the plots. If you do this for one scatterplot, the action is broadcast to all scatterplots in the window, and they resize together. Any other types of plots remain unchanged.
Specify Size in Pixels
To resize a plot or graph to a specific pixel size:
Right-click the plot or graph.
Select
Size/Scale
Frame Size
Enter the number of pixels for the frame’s height and width.
Note:
For details about the other options in the Size/Scale menu, see
Scroll and Scale Axes
Help created on 3/19/2020
