Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Using JMP
JMP Reports
Change the Appearance of Graphs
• Zoom In and Out
JMP.com/help
Zoom In and Out
The magnifier
lets you automatically zoom in on any area of a plot. When you click the magnifier, the point or area where you click becomes the center of a new view of the data. The scale of the new view enlarges, giving you a closer look at interesting points or patterns. You can perform any of the following actions:
Click and drag the magnifier to focus in on a particular region of the plot.
On a ternary plot, drag the magnifier to zoom the triangular axes.
Zoom repeatedly to look closer at the data.
Hold down the Control key and click the magnifier to return to your previous state before the last zoom.
Double-click or hold down the Alt key and click the magnifier to restore the original plot.
On Windows, you can also zoom by holding down the Control key and using the mouse wheel.
On Macintosh, zoom by pressing Option and clicking the area.
Note:
You can zoom in and still see a center point by dragging from the axis to inside the graph. For a vertical axis, click on a position and drag right into the graph. This zooms in on the scale, adjusting both endpoints of the scale but keeping the clicked value in about the same position. Dragging left zooms out.
Help created on 3/19/2020
