Tip: Alternatively, you can use the EMP method to assess your measurement system. See the Measurement Systems Analysis topic.
The process variation, from one part to another. This is the ultimate variation that you want to be studying if your measurements are reliable.
The variability inherent in making multiple measurements, that is, repeatability. In Table 8.1, this is called the within variation.
