Copy a graph from within JMP or a graphic from another application and then select Edit > Paste. JMP places the graphic at the end of the journal.
Drag and drop the graph or graphic from another window to the journal. (See Paste a Background Image into a Graph in JMP Reports.) A blue line indicates where you can drop the graphic.
