To adjust text wrapping, right-click the text and select Set Wrap. Enter the number of desired pixels per line and click OK. To apply the wrap to all text items, select Set Wrap, select Extend this to other text boxes, and then click OK.
Right-click the plot or graph, and then select Size/Scale > Frame Size. See Resize Graphs in JMP Reports.
