Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Discovering JMP
Save and Share Your Work
Save Platform Results in Journals
• Add Analyses to a Journal
If you perform another analysis, you can add the results of the analysis to the existing journal.
With a journal open, select
Analyze
Distribution
Select
profit/emp
and click
Y, Columns
Click
OK
Select
Edit
Journal
. The results are appended to the bottom of the journal.
Help created on 7/12/2018
