To start a new project, select File > New > Project. A window appears that shows the untitled project.
Click Open.
Figure 5.127 Initial Project
Create a group for the data tables by selecting New Group from the Bookmarks red triangle menu. The group organizes the files but does not move them on your computer.
Figure 5.128 Bookmarked Files
In Car Physical Data.jmp, run the Contingency script.
In Car Poll.jmp, run the Distribution script.
Figure 5.129 Tabbed Reports
Drag the Distribution report tab to the right until the Dock right zone appears on the far right.
Figure 5.130 Dragging a Report
Drop the report into the Dock right zone.
Figure 5.131 Report in New Pane
6.
When the Dock tab zone appears, drop the report.
Figure 5.132 Docked Report Tabs
