In this example, you use singular value decomposition of the transaction item matrix to gain further insight into the Grocery Purchases.jmp sample data.
Select Analyze > Screening > Association Analysis.
Click OK.
7.
Click OK.
Figure 20.5 SVD Plots
8.
Click the red triangle next to SVD and select Topic Analysis, Rotated SVD.
Figure 20.6 Topic Items Report
Figure 20.7 Topic Scores
Figure 20.8 Singular Values Table
As seen in Figure 20.8, the first two singular values explain only about 30% of the variability in the grocery store data. Additional dimensions might be required to explain a sufficient amount of variability.
