Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13 Online Documentation
JMP 12 Online Documentation
Control Chart Builder
• Additional Examples of the Control Chart Builder
Note:
In this section, some examples show the Control Panel while others do not. To show or hide the Control Panel, select Show Control Panel from the red triangle menu.
X-Bar and R Chart Phase Example
p-chart Example
np-chart Example
c-chart Example
u-chart Example
g-chart Example
t-chart Example
3-Way Chart Example
Help created on 7/12/2018
